Auteur Topic: Levi's 850 2.5 10v LPi Grijs  (gelezen 18460 keer)
Levi_r
  • 850 2.5i 10V Lpi '97
Re: Levi's 850 2.5 10v LPi Grijs
« Reactie #180 Gepost op: 15-02-2020 02:53:00 »
Na inmiddels goede 600 km en meerdere keren stroomloos maken, komt de foutmelding toch steeds terug. VIDA zegt het volgende bij 113 (of eigenlijk 1-1-3):
Citaat
Diagnostic trouble code (DTC) information 1-1-3
Condition
Short-term fuel trim indicates the amount by which basic programmed injection time must be varied to achieve optimum fuel/air mixture. If the control module finds the engine is running lean, short-term fuel trim increases to extend the injection time and restore the mixture to its ideal ratio. If the engine runs so lean that the short-term fuel trim reaches its maximum (upper limit) and stays there for 3 minutes, the system records diagnostic trouble code (DTC) 1-1-3.
Under certain conditions the ignition coil can generate a pulse which interferes with the operation of the engine control module (ECM) which causes diagnostic trouble code(s) (DTC) 113 and/or 112 to be stored and activates the engine malfunction indicator lamp (MIL).
Substitute value
The integrator is set to its central value and adaptation is disabled. When the engine starts, the short-term fuel trim resumes control of the injection time until the diagnostic trouble code (DTC) condition is met once more.
Possible source
- Contact resistance in heated oxygen sensor (HO2S) connections.
- defective heated oxygen sensor (HO2S).
Fault symptom(s)
May result high fuel consumption and driveability problems.
Voor deze foutcode lees ik dus dat het wel echt in de sensor zou moeten zitten. Morgen maar even de 'oude' terug zetten. Daar weer even een weekje mee rijden en mocht het dan wat beter zijn gewoon even voor een nieuwe gaan.
Projector inbouw part I
850 2.5i 10V Lpi '97 Dark Grey Metallic | 850 2.5i 10V Lpi '95 Dark Olive Pearl | V70 2.5i 20V Lpi '00 Nautic Blue
spijky
  • Clublid.nr.: 85011565
  • Lid 500+
  • Love Is In The Boost
« Reactie #181 Gepost op: 15-02-2020 09:34:29 »
Ik heb eigenlijk altijd als eerste de lambda sonde vervangen van auto's die ik kocht.
Niet omdat ik storing had, maar puur preventief.
De oude zijn meestal traag. Met een OBD kast heb ik toen ook  al meerdere malen gezien dat de regelsnelheid (rijk/arm) misschien wel 2 a 3 keer zo snel was.
Ik zou er gelijk een nieuwe inzetten.
My Bricksquad:
850 2.3 T-5R AUT Cream Yellow
Menno3274
  • S70 T5 (412-21) '97
« Reactie #182 Gepost op: 15-02-2020 10:08:41 »
Helaas, ben ik mooi "opgelicht" vorig jaar. Snel een echte nieuwe halen dan :)
Levi_r
« Reactie #183 Gepost op: 15-02-2020 15:50:26 »
Ja, jammer dat de sonde niet goed lijkt te zijn. Heb vanochtend de 'originele' weer teruggezet, en het lijkt gelijk weer stukje beter qua verbruik in ieder geval. Een kleine 20 km gereden, dus kan er ook nog niet zo veel van zeggen.
Wat me wel opviel: de originele sonde heeft en 'VOLVO' er in gestanst staan en het volgende nr 9135329 NTK A4F.
Dat is toch net anders dan de OTA4N5B1  wat ik verder tegenkom. Wellicht een ouder nummer of is er voor mijn auto toch een ander type sonde nodig...? Opvallend is dat bijv. estateservices 9135329 en ota4n 5b1 in dezelfde omschrijving zet: https://www.estateservices.nl/motor/brandstofsysteem/lambda-sensoren/lambdasonde-850-v70-voorste-ngk-origineel.html
« Laatst bewerkt op: 15-02-2020 16:00:43 door Levi_r »
    • Volvo foto album
« Reactie #184 Gepost op: 15-02-2020 19:13:57 »
9135329 is het volvo onderdeelnummer. OTA4N-5B1 is de type aanduiding van NGK/NTK, de fabrikant van Volvo onderdeelnummer 9135329. Het artikelnummer van NGK/NTK zelf is 1765. Volgt u mij nog?  ;D
gero
  • Lid 500+
  • Volvo 850-10V-Honda Fire Blade-Gero&Lara-V70R
« Reactie #185 Gepost op: Gisteren om 08:55 »
Ik heb nog een nieuwe op de plank liggen, is deze nou de juiste voor een 2.5  10 V.??
https://imgur.com/1P9Ph6p
Menno3274
« Reactie #186 Gepost op: Gisteren om 17:21 »
Zou de goede moeten wezen :)
Levi_r
« Reactie #187 Gepost op: Gisteren om 19:07 »
Lijken zeker de goede nummers. Heb er gisteren net een besteld, anders had ik 'm graag van je over genomen.
gero
  • Lid 500+
« Reactie #188 Gepost op: Gisteren om 19:37 »
Gelukkig maar !!  deze is voor mijzelf, moet het alleen nog monteren.
Levi_r
« Reactie #189 Gepost op: Gisteren om 23:08 »
